Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Beam not detected as Main Part
6 REPLIES 6
muazmohsin9644K5V
629 Views, 6 Replies
I got problem during numbering my model. My beam is not detected as main part even it's heaviest part.
So it be a single part that attached with my column.
I attached photo below as reference. (Red highlighted is a assemblies part of column)
Thank you in advance
Tags (1)
Labels (1)
6 REPLIES 6
if it's connected and you number with the checkbox "mainpart", there should be no problem. Your pic is not really full of informations, maybe you upload a model of more pice
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
here is my file of model
you connect a lot of elements to one mainpart (the blue marked is the maipart itself):
Are you sure, that this will be one assembly?
Sebastian Eiche
Actually I do not want to make that as one assembly, but my custom connection got problem(Where what is my problem now). Every my custom connection now make every structure as one assembly. I hope there is a way sir. thanks in advance 🙂
This is because your bolts are set to shop. Change it on site and will be no problem
Sebastian Eiche
Yes it works. thanks sir
