Beam lines not trimming after apply cut to beam etc
Message 1 of 9
Hi Everyone
I am facing problem with Beams see below image.
when I apply cut at object or mitter but there are still beam axis line showing in red.
could someone explain why and how to correct it.
Thanks and Regards
Muhammad Ismail
Replies (8)
Message 2 of 9
Karsten_Bork
yes, normally the red axes line keeps but you can stretch or trim on a line or surface with Advance Steel Tool before.
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Karsten Bork
Mensch und Maschine acadGraph GmbH
Message 3 of 9
Sebastian_Eiche
the line you mean is the system line, by using the cut command, you only cut the beam solid but not the system line.
This is a very important function, because for a few import and export commands, not the beam itself is exported, it's the system line which is used.
And so if the red system lines are not connected to each other, it could be a big problem to export the model to a static design software.
If you want to cut the red line, please use the extend trim command of the tool palette:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
Message 4 of 9
Thanks very Much for your information but when applied
the results different as shown below. the beam part going backword.
is not there anything where the system line can only be extended upto beam maximum lengths only.
Thanks and regards
Muhammad Ismail
Message 5 of 9
Karsten_Bork
Hi Muhammad,
it seems you have a shortening in your beam, please change the visibility of the beam, delete the green shortening.
If you use the button normaly it works fine. Important, stretch and trim the beam bevore you use this button!!
Karsten Bork
Message 6 of 9
Hi Karsten thanks for swift response.
Could you please explain
how to change visibility?  it the conceptual or realistic views etc or something else.
I have tried multiple time for using cut at object tool as you mentioned. but it didn't extends to the other beam surface. just a grey box appears only.
Thanks and Regards
Muhammad Ismail
Message 7 of 9
Karsten_Bork
Hi Muhammad,
you need an Advance Steel training! 🙂
Wizh doppel click on grey box you will this window, please check if you have a cap:
If not, please delete the green rectangle, maybe it's twice in the connection and if the the gray box is also delete, no problem, delete all green rectangles. after you create a new cut on object and it works.
Karsten Bork
Message 8 of 9
thanks I have checked and there were 2 green rectangles one at cut area and one at top surface of lower beam.
after deleting the top rectangle it got fixed.
Thanks and Regards
Muhammad Ismail
Message 9 of 9
Make sure the two beams in question are intersecting or atleast touching each other.
That's the only way the trim command will work. This is because one beam acts as a reference to cut against the other.
