Batch Plot problems
Batch Plot problems
anmike2003
Batch Plot problems
anmike2003
When I used batch plot in advance steel ,from DWG to PDF in bluebeam , letters and number are cover we black mark ,please see the attachment THanks
Drawtech
This also happens when using the Autocad publish command with the "Publish in background" option checked.
It seems to be a problem with the recent text background/blackout feature.
...the workaround I use is the Autocad publish command with the "Publish in background" option NOT checked. Then it works fine.
Hope this helps you out in the meantime 🙂
Dave Gronow
Drawtech Services Ltd
arkli2009
Try Force Update the drawing.
hayley85
I would like to ask you some advice for the Batch plot .
My PDFs come out some in BnW, some in colors ,doesn't matter I added them all in the same Batch or different batchs even with different plotters. Could you please advice me any way around to have the consistent outcome?
Thank a lot!
