There is nothing you can do to change the file name format of the PDF batch plot. I imagine there are various ideas for this on the IDEA Station for Advance Steel.
However, the "Advance Steel A3" part of the file name is the Layout name from the drawing file. If you edit your prototypes so the layout space name is simply A3 or similar then you will get much shorter file names.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
