Batch Plot output folder
HarryHighpants
HarryHighpants
I'm trying to set the output folder for 'batch plot'.
At the moment the PDF's are going into the same folder as the 3D model, which means I need to move the PDF's each time.
I find this a bit cumbersome not to mention dangerous.
Anyone know how to set the folder?
CHRIS_ASDL
I use the Batch Plot feature direct from Autocad. You can set the destination folder and do multi-sheet files. Definitely the best way if you want everything organised correctly.
Kind Regards
Chris
HarryHighpants
Thanks @CHRIS_ASDL, that might be the way to go. I'll look into it.
hi, publish is also working great. I am always using this function.
CHRIS_ASDL
Your welcome @HarryHighpants. Is a shame this feature wasn't included in AS2017. Hopefully it will be soon as it's something that the DM is lacking!
Kind Regards
Chris
HarryHighpants
Hi @Anonymous. Is there a difference between batch plot and publish?
no, the same
