Base View Command Problem
SMPConsulting
SMPConsulting
Hi all AS users,
I'm having problems trying to create a base view from a model that is partly created with Autocad solids and partly AS entities.
When I create the view I either get a partial view which only includes the Autocad solids or the program locks up and I have to terminate the program and restart AS.
Anthony Paul
www.smpconsulting.com.au
An Inventor user since IV6 2002, and a 3D AutoCad user since R9 1989
i7 7770 @ 3.6GHz – 4.2, GB H110M M.2 Mainboard, 2 x 8 GB DDR4 RAM
250 GB SSD 960 Evo Series SSD, 700 W 80+ ATX Power Supply, Win 10 Home 64 Bit
Sebastian_Eiche
Maybe you upload the model or a Screencast, only from your post it's not easy to find the problem.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
AleckGiles
I wouldn't use Base View. I doubt it will handle the Advance Steel objects properly. Instead create a normal AS GA drawing with a suitable overview or 3D GA style. To get the AutoCAD solids to show in the drawing depends on how you do the drawing:-
If using the Drawing Styles palette then you should select all the solids before clicking on the style on the palette. The selected solids should show in the drawing.
If using Cameras than check your default Drawing General > General > Allow detailing of CAD entities inside Camera Drawings is ticked (update defaults if you change it) before generating the vie from the camera (running the process).
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
