I am doing the design of a base plate and I get the following message:
It is referring to the baseplate resistance. Moment resistance check - 58.94 %.
When I generate the report, it does not describe specifically what is wrong. The thinkness of the baseplate along with the stiffeners tells me that is should be more than enough but I do not get what is the error.
Thank you
