Is Advance steel able to produce (from the connections vault) the bracing shown in the screenshot?
2 RSA's back to back, either side of gusset.
Rob
Solved by johnjmbennett. Go to Solution.
In reply to this you can use the bracing macro to create and place the elements in the model, for the gusset plate connection there is a specific one within AS for this under general bracing.
The trick if using that connection is to select both the back to back angles as the first diagonal, then repeat for the second one and third.
To show workflow please see screencast below
Screencast : https://autode.sk/2FcYR6T
Cheers
John Bennett
