Announcements
Automatic hole and bolt extend
robert.seligo
robert.seligo
I have two plates connected with bolts. Now I want to add third plate to this bolt connection. Is it possible to add this plate in a way that holes and bolt will be automaticly added to third plate? Now i delete bolts and create them again from start.
Thanks for all help, greeting.
mick-CNF
Select the bolt/weld then the item to add.
If this information solves your problem please accept as a solution.
