Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Automatic hole and bolt extend
1 REPLY 1
robert.seligo
153 Views, 1 Reply
I have two plates connected with bolts. Now I want to add third plate to this bolt connection. Is it possible to add this plate in a way that holes and bolt will be automaticly added to third plate? Now i delete bolts and create them again from start.
Thanks for all help, greeting.
1 REPLY 1
mick-CNF
in reply to: robert.seligo
Select the bolt/weld then the item to add.
If this information solves your problem please accept as a solution.
