Autodesk advanced steel 2016
Hi,everybody. I am runnung Advanced steel 2016, and i have a problem with beam splice command. Top flange plate and bolts do not show up, does anybody else have the same issue?
Kirk_bailey
you post a screenshot or screencast of your issue? i could probably help you out here if i could better understand the situation.
Thanks for the response, I have to define beam splice with web splice and top and bottom bolted flange plate, but it doesn't matter what I do, only bottom flange and bolts shows up in the model and in the shop drawings, but not the top flange plate of the beam splice.
hi, command is working ok.
all plates are in the model, with or without bolts. no problems overhere.
so, it seams to be a personal issue.
Try it with another beams from another class, look if it works.
Try and error methode.......
thanks, replaced the beam and everything start to work
