AutoCAD solids to Advance Steel
FProcp
FProcp
Autocad 3d solids brought into Adance Steel as "Special Parts" do not print very nicely.
Is there any way to get rid of the tessellation lines?
Franco
GMT +08:00
lk
I have the same problem from long time, but it seems there is no solution 😞
The second is that the special parts causes unexpected collisions. For example: round pin in the bigger hole causes crashes because AS doesn't treat those shapes as round but as polygons. Crashes cause that drawings are sometimes created with bugs, like visible lines that should be hidden etc.
It is very very annoying because special parts are great feauter of AS. It let us to use AS not only for buildings but also for specific structures in power plants, offshore steel etc....but see above
Leszek K
Hi, got the same issue...
Have a smooth representation would be great... Should post somthing in IdeaStation...
FProcp
This has now been posted to IdeaStation.
Search for:
"AutoCAD 3D Solids as "Special Parts" in Advance Steel need to Print Better!"
Franco
GMT +08:00
