Is anyone else having trouble installing autoCAD service pack 164bit with ADVANCE STEEL 2015 installed?
I get the error shown in the picture atttached.
I downloaded That service pack directly from autodesk. AutoCAD_2015_SP1_64bit.exe
Im using acad 2015 and as 2015
nope didn't run into this issue
that error could be the wrong bit was downloaded/installed or the completely wrong autocad service packs was downloaded/installed
DarrenP
That was my initial thoughts too. So I double...triple....quadruple checked
64 bit - correct
acad 2015 - correct
sp1 not installed yet - correct
Really strange. Even the autodesk application manager doesnt show the service pack, Im at a total loss.
I do however have an advance steel 2015 hotfix installed.
I hate upgrading 🙂
Hello Vinnie,
The only time I have had this error is if we are trying to install for example an AutoCAD Mechanical SP on a workstation with only AutoCAD (vanilla installed). Why not try to update your applications via the Autodesk Application Manager ?
Actually I use the Application manager exclusively, This time however I knew there was a service pack and it did not show up on the application manager.
The hotfix #2 for advance steel showed up in it and a few other updates but never any service pack. Im beginning to wonder If I have a bad install.
Everything seems to work beautifully.
What product version are you on? Mine says J.141.0.0 Autodesk AutoCAD 2015 and for advance steel build number 9708
Thank you for your help.
Hello Vinnieb,
Your AutoCAD 2015 build - J.141.0.0 - includes already the SP1; you have a newer build.
So, it is normal to not be able to apply the SP1.
Emy
