Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
ASTOREXPLODETOACIS
1 REPLY 1
jasno
205 Views, 1 Reply
ASTOREXPLODETOACIS
Hi
My costumer want to open 3D model in pure ACAD and check properties like in AS (Profile, weight...) without object enabler
After using ASTOREXPLODETOACIS he can open it but properties are not visible like AS.
How to do it?
1 REPLY 1
Rob_Merriman
in reply to: jasno
Hi @jasno
Thats not possible, once you explode to ACIS the objects are just extruded 3D solids so they have no properties at all.
If they want to view the model in AutoCAD with the properties they will have to install the object enabler.
Have you looked at using Shared views, your customer would be able to view the model in a web browser with all the properties and then they can measure etc
https://knowledge.autodesk.com/support/advance-steel/getting-started/caas/simplecontent/content/shar...
I have done a webinar on shared views which you can watch on demand here - https://youtu.be/rWHX6VlOEP8
Rob Merriman, AEC Technical Lead, Graitec
