Good morning,
I would like to have the assembly mark in the DSTV file, to identify in which assembly the part is assembled.
In my example I would like to show K3 in plan identification. I set the assembly or secondary mark variable. But it is the secondary benchmark that is noted.
Do you have a lead? Thanks in advance.
Good morning,
Solved by Sebastian_Eiche. Go to Solution.
if you use the token "%posnum" the token will handle the number as the object is used in the model.
If a beam is the mainpart of the assembly the Mainpartnumber will be shown. if the beam is just an attached part, the Singlepartnumber will be shown.
You could change it to the token you need
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
Thank you for the explanation, but unfortunately I will have to look for another avenue.
