AS2021 and Navisworks not getting along
markhubrich
markhubrich
I can't get around the Z orientation issue with 3DDWF export because I'm sending my model off for coordination by others.  I installed the 2021 Navisworks exporters to try NWCOUT. AS2021 crashes. I tried opening the DWG of my model in Navisworks, it crashes.
...and fix the kiss export issues.
Sebastian_Eiche
no problems here. Could you try to rename your AS2021 folder in C:/programdata/Autodesk and then doing a repair within the windows control:
And then open AS without any migration and try the navisexport
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Type a product name
