AS to DWG Trueview Compatibility
will5L99Z
will5L99Z
Morning All,
I have just sent a model DWG to our engineer to review, he has DWG Trueview 2018 and is saying that he cannot see anything?
Is there any issues with these?
Sebastian_Eiche
What AS version do you use?
it should work if the other one install the object enabler, for example for the version 2019: ADesk
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
will5L99Z
Morning Sebastian,
I use AS2020, He has Trueview2018 but says when he opens my drawing he only sees a few lines.
Will give the object enabler a go.
Thanks!
Sebastian_Eiche
Yes this is right, Advance Steel dwg contains ProxyElements.
If you use 2020, he will need the object Enabler for this version: 2020
Sebastian Eiche
pendean
Community Legend
Community Legend
Everyone needs to be using 2020 versions, DTV2020 needs the 2020 enabler installed as well https://knowledge.autodesk.com/de/support/advance-steel/downloads/caas/downloads/downloads/DEU/conte...
