AS API positioning profile with refaxis / offset
Hi, everybody.
I am trying to put the "refaxis" off the cross-section, so I followed this topic:
https://forums.autodesk.com/t5/advance-steel-forum/as-api-profile-positioning-with-refaxis/td-p/8447...
But I only managed to set the axis to the corner of the profile section using the first line of the following code:
myBeam.RefAxis = Beam.eRefAxis.kLowerLeft;
myBeam.Offsets.Set(10, 30);
I need an offset and it seems "myBeam.Offsets.Set(10, 30)" is not working!
Any Ideas?
ChristianBlei
the offsets is a 2d vector.
public Autodesk.AdvanceSteel.Geometry.Vector2d Offsets { get; set; }
    Member von "Autodesk.AdvanceSteel.Modelling.Beam"
so try
Vector2d v= new Vector2d(20,30)
myBeam.Offsets.Set(v);
HTH,
Christian Blei
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
Thanks a lot ChristianBlei,
Actually "Offsets.Set" has no overloads for accepting a Vector2d, but your
answer gave me the clue to solve the problem as follow:
Vector2d v = new Vector2d (20, 30);
myBeam.Offsets = v;
ChristianBlei
isn't the type of Beam.Offsets just Vector2d?
Christian Blei
christianblei.de
It is.
I meant the "Set" function only accepts two "double" arguments, not a "Vector2d". So, I assigned the vector2d to the "OffSets" directly without using the "Set" method.
In fact, the code below is not working as it is expected to accept two doubles and create a "Vector2d" and assign it to the "OffSets" method
myBeam.OffSets.Set(double x, double y);
But instead, as you mentioned this works:
Vector2d v = new Vector2d(double x, double y);
myBeam.OffSets = v;
ChristianBlei
here are explanations for the set and get accessors of properties in C#. you may have a look.
Happy coding and a happy 2020!
Christian Blei
Christian Blei
christianblei.de
