Hi All,
Iam not sure what I have done or what setting I have changed but I keep getting this annoying dialogue box that keeps popping up every time I do a command.
Please see screen shot.
It would be good to have a solution to this.
Thank you.
Solved by johnjmbennett. Go to Solution.
Look up autodesk cycling command, this dialog is for that option, if active it is seen in the system tray at the bottom of the screen, also listed under the hamburger icon bottom right of screen. Just turn it off.
John Bennett
Thank you very much you have just saved be from a big headache.
I really appreciate this.
