Angled Section to Angled Section with a Plate
njownby
Message 1 of 9
njownby
Community Visitor
Community Visitor
Hi All, I am trying to 3D model a Transmission Line Tower in Advanced Steel, but I am running into an issue. Where the legs of my tower meet the body, I am trying to add just a steel plate to connect the cross members to the main leg. It is all with Angled Sections. Is there a way to add one or create my own to add in?
Thanks!
Replies (8)
Message 2 of 9
Tomislav.Golubovic
Yeah, use the Plate Macro then bolt them all together.
Where is the plate to be located?
Message 3 of 9
Flies-Eyes
Have you looked into using the Transmission Tower macro for Advance Steel that Graitec have developed?
Message 4 of 9
bigcarl5000kg
in the Graitec PowerPack for Advance Steel, there are actually no connections especially for Transmission towers, if I'm not mistaken
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 5 of 9
Flies-Eyes
Interesting.
Message 6 of 9
njownby
Community Visitor
Community Visitor
Well, the problem is with the plate macro is that all of them are for beams or other items except for Angled Sections. I just need a standard flate plate that I can add bolt holes to, to make it fit what I need. Is there any way that I can make my own plate in AutoCAD and add it in?
Message 7 of 9
Tomislav.Golubovic
Have you used the plate macro to make just a plate?
Message 8 of 9
D_Waeldele
You can also use the macro "plate parallel beam" and then screw the parts together
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Sorry, this text was automatically translated.
Message 9 of 9
bigcarl5000kg
Hi @njownby,
if it is just a screw connection between any profile and leg using sheet metal (not welded on), create sheet metal manually on leg (first ucs on leg) and and then use the 2x the function Bolts on beam (leg and plate, profile and plate), which will help you to place bolts in the leg and profile parametrically. Finally, adjust the shape of the sheet as needed. You can also later create a user connection, but only after you gain enough experience with the basics. Unfortunatelly, Advance Steel does not have many joints for transmission towers, we had to create them a lot too (the fun begins when the leg and profile do not have parallel connection surfaces (there is a wedge-shaped gap between them)
