Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
ANGLE AS END PLATE
2 REPLIES 2
dcalderonobonaga
148 Views, 2 Replies
ANGLE AS END PLATE
Hi Team, I have a curved roof system, so i need to move up just the purlin, it will be welded to an angle, so I created 2 End plates connection, cuz the angles clips always attach on the side of the purlin instead at the end how I needed, thinking 2 steps ahead about numbering and assembly, it will be 2 parts, how I can make it 1 single part, I tried merge plates, didnt work. what are your recommendations.
Labels (4)
2 REPLIES 2
Hi @dcalderonobonaga ,
as one connection element, your solution can be a bend plate or L-Profile (without radius on the inner side = possibly another problem).
This can be done via Custom (user) connection - you "put together" e.g. two beams via connection material (plates, profiles, bolts, welds, ...):
Example for complex Custom connection:
Custom connection may contain many other macros (connections) - you apply this  and after deleting the main blue box you have still possibility to make changes on these macros.
You will find a lot of sources to this:
https://www.youtube.com/watch?v=dNqQzCd49M8
https://www.youtube.com/watch?v=cftaBwnvluQ
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Thanks, I'll try it and let you know.
Technology Administrators
