Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
All labels now italic?
30 REPLIES 30
Message 1 of 31
1966 Views, 30 Replies
I've just updated to AS2017.
I have an issue where my label text is shown as italic, even though the italic options are unchecked.  Any ideas where to look to fix this?
30 REPLIES 30
Message 2 of 31
dave_conibear
well Paul........we must be the only two users experiencing this problem
Any one from AutoDesk on this yet?
Message 3 of 31
CHRIS_ASDL
in reply to: dave_conibear
Apparently this is happening to a lot of people who upgraded to AS2017, myself being one. Graitec UK are aware of this and are looking into it.
Kind Regards
Chris
Message 4 of 31
dave_conibear
in reply to: CHRIS_ASDL
OK...........good to know...........I guess that's why my Case Number hasn't been closed out yet  Smiley Wink
Message 5 of 31
Same here on Australian release. Who checks this stuff?
Message 6 of 31
Same thing on french release... Having trouble with explode command on special parts to... Someone experiencing this ?
Message 7 of 31
ads_bunescc
Hello @paul,
Thank you for your posting. It has been escalated to the developing team and it is under active investigation for resolution.
Message 8 of 31
dave_conibear
alerat..........if you need to explode the part............maybe explode in pure AutoCad then re-insert.........but sure.........it's the same for the English release........why wouldn't it be !!!!
just out of interest........where are you.....me.........91600
Message 9 of 31
Emanuel.Nestor
Hi Paul,
Could you please send me a model and the detail drawing showing the issue ?
I will take a look right away on it.
Thank you
Best regards,
Emy
Emy Nestor
Message 10 of 31
I m from 47000
Message 11 of 31
Had a play, restored the system to default using the repair feature and this time did not convert the databases from 2016 and the problem has disappeared, no more italics.
I then converted the following 3 databases AstorBase, AstorDetails and AstorSettings, then when I went back and created a test model I then got italics again.
My conclusion is there is an issue in the converson process in one of the 3 databases. I will try and isolate which one is the issue.
Message 12 of 31
OK, it looks like the AstorSettings conversion is the problem. The other databases don't cause this issue. If you are having this issue then you have most likely followed the Autodesk recommended migration including the databases and you will need to repair the install.
Message 13 of 31
HarryHighpants
I'm having text issues as well.
You're right there's a problem with merging databases, the settings come in all wonky.
I tried importing a profile settings xml file and deleting the merged one, and that worked ok, but it doesn't fix the problem with the funny text.
I'm beginning to wonder if this software in a perpetual state of Beta release.
Message 14 of 31
Ironically, I had predicted problems with migrating to 2017 but foolishly went through with it anyway.
That is why I started a thread asking people what is the correct way to migrate. I suspect nobody (least of all Autodesk) know the answer.
Their published guidelines are little more than a re-hash of the previous guidelines.
Message 15 of 31
wslomiany
in reply to: HarryHighpants
Happens to me too. Italic text in the shop drawings.
Once again the conversion process has been quite wonky.....migrates some entries not others. Especially for custom API conn rules and such.
Had hopes this year that things would go a little smoother but I have found that I cannot trust the CONVERT DATABASES feature in Management Tools.
An Access merge tool like AccdbMergePro helps a little.
Message 16 of 31
Kirk_bailey
in reply to: wslomiany
Can this tool damage you databases?
Message 17 of 31
wslomiany
It makes a backup of files but I always recommend to copy all orig A/S files and have them as back-up in case you need to start from scratch.
Please note when replying via email any signature used by your email client will be added to your post as with any other email.
Edited by
Discussion_Admin
Message 18 of 31
wslomiany
Changing the font in the DEFAULTS of MT to txt, saving settings and updating defaults.... then going back and chaging it BACK to arial (or wahtever font you want) fixed it for me. Update any drawings you should be good.
Message 19 of 31
dave_conibear
...........fixed it for me too.........top banana.......top solution wslomiany....that deserves a big fat kudos
Message 20 of 31
in reply to: Emanuel.Nestor
Well, after updating my software to the latest Hotfix (AS2017 Build 1024) my text has now all changed to the font "txt.shx" although that is not the font selected in my Management Tools.  Arial is what's shown in my Management tools.
Even weirder, when I changed the font name in Management tools from "arial" to "Arial" then things started to work properly again.  Apparently Management Tools font selection is case sensitive?
