Advance Steel to Solidworks?
Drawtech
Message 1 of 11
Drawtech
Hi All,
Further to yesterday's post re the empty DXF files, it turns out that my client's supplier (Parker Steel) cannot read them anyway - they use Solidworks as an interface to their tube laser cutting machine.
Does anyone know how to get Advance Steel parts or a whole model into Solidworks?
We have tried STP files via the PSS and CIS/2 exports.  Also we have tried exploding the model into AutoCAD solids and using the AutoCAD export to IGS and STL.
None of the files can be read successfully - all blank or the imported objects are not solids or will not import at all.
The STL came closest but is imported as one object in Solidworks so cannot be split into the parts.
Surely there must be a way to do this?
Cheers,
Dave
Dave Gronow
Drawtech Services Ltd
Replies (10)
Message 2 of 11
Sebastian_Eiche
as I know Solidworks could import: IGES, STEP; ACIS.
So if you want to have single object, you need to export them as single files and then import them. So they should be single object in Solidworks.
But I have not used it, so this is only a suggestion. But if the behavior is similar to Inventor this should  work.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 3 of 11
Drawtech
Thanks Sebastian.
We did not have any success with the STP files created from Advance Steel via the PSS and CIS/2 exports. I could not see any export option actually called STEP.
The IGES only seems possible by exploding to AutoCAD solids and using the AutoCAD export, but this was also unreadable. Even if it were, there is no option to select objects, so would require splitting the model up into one file per part before exporting - that would be a lot of faff!
Had not tried ACIS (*.sat) so have now sent a file to see if they can read it.
Dave Gronow
Message 4 of 11
Sebastian_Eiche
the stp files which are created by using CIS/" or PSS are not STEP files 😃 --> same file extension, different files.
stp files from CIS/2 or PSS have a different file sheme than step. I'm not sure why they use the same extension, but they are different. STEP are solids, the other format could be imported as and then AS create beams, plates and so on. this is used from other steel detailing software like tekla, bocad or prosteel. strucutral software could sometimes import this files too, for example RStab
AutoCAD itself could not export STEP files, only ACIS.
Sebastian Eiche
Message 5 of 11
Hi Dave,
if you find a way to to do this, I am really interested to know how.
In the meanwhile, did you consider to skip your clients supplier software, and generate .nc (.dstv) oldskool machining files?
It depends on how complex the operations on the pieces are....
Kind regards,
Willem
Message 6 of 11
Drawtech
Hi Willem,
We tried the usual NC output first, but the supplier's tube laser cutting machine is only controlled from Solidworks.
Dave Gronow
Message 7 of 11
Sebastian_Eiche
tube lasers often need step files, because nc files for laser cutters for profiles uses surfaces like flange or web. this is not defined for tube. So the most need 3D solid often by importing step.
Step files have different versions (AP203,AP214, AP242) and so the cutters don't read them all. for this some customer use another software to create the files which the cutter "want"
Sebastian Eiche
Message 8 of 11
Drawtech
Thanks to all for your input.
After trying many different things and almost giving up, I found the solution was a Plugin from "Man and Machine".
Demo here:
https://www.youtube.com/watch?v=UkfDNS2xKXY&feature=youtu.be
It's a great add on, reasonably priced and solved my problem in a very user friendly way.
Hopefully Autodesk will look to add this to the main AS package!
Dave Gronow
Message 9 of 11
Masibanda-CE
Glad you found a solution! I came across this a bit late but was going to ask you to send me your model exploded to ACIS objects and then I'd run it through Bricscad and export it from there. I use it a lot for similar "transformations" and most often it works. I use this workflow to create IFC files because AS usually crashes when directly trying to export to IFC. I think it has to do with the large number of Special Parts we use. I can import any MCAD type of file into Bricscad and save as DWG, and below is an export comparison:
Message 10 of 11
Drawtech
Thanks for the thought anyway! 😊
Dave Gronow
Message 11 of 11
Drawtech
We also found that exploding to AutoCAD solids and using the AutoCAD export to “Other Formats” and using the ACIS (*.SAT) option was successfully imported into Solidworks as solids.
…the other options like IGS did not work.
Dave Gronow
