Advance Steel Projects Gallery
MRizea
Message 1 of 109
MRizea
Hello everyone,
I was thinking that it would be a good idea to post some pictures with our projects. If it's possible, model pictures and the actual building that's been build.
I'll start...
Replies (108)
Message 101 of 109
george1985
@markhubrich wrote:
Here's one for when your daily grind isn't providing enough entertainment. (FILES ATTACHED)
Advance Steel Project Starts Life With Rhino & Grasshopper
https://knowledge.autodesk.com/search-result/caas/screencast/Main/Details/1a359952-5d93-48a5-82fa-b4...
canopy grasshopper.jpgCANOPY IN ADNAVCE STEELCANOPY IN ADNAVCE STEEL
Hi @markhubrich ,
Thank you for sharing this project and files with us. Amazing work you did!
How did you import the truss axes from Rhino to Advance Steel? As a .dxf file? How did you convert all those truss axes to Advance profiles?
Message 102 of 109
acbsdesign
@StefanoPasquini6790 wrote:
Dear @acbsdesign ,
First of all I want to meke you my personal congratulations for your marvelous works with Advance Steel. I have some questions for you:
  1. How do you manage this big projects? Whe have some difficulties in managning over 100 steel tons models...due to ACAD limits;
  2. What is your workstation properties?
  3. How do you manage you construction drawings?
Hope you'll have a very good Easter, I send you my best regards
Thank you for the kind words.
Below are the spec's of my current workstation, used to work with ApexxS3 by Boxx from 2018 to 2022, tried something different. Overclocked at 5.5P, 4.1E.
UserBenchmarks: Game 171%, Desk 126%, Work 198%
CPU: Intel Core i9-12900KS - 128.8%
GPU: Nvidia RTX 3060-Ti - 133.1%
SSD: Samsung 980 Pro NVMe PCIe M.2 1TB - 421%
RAM: G Skill Intl F5-6600J3440G162x16GB - 206.3%
MBD: MSI PRO Z690-A WIFI (MS-7D25)
The weight of steel has never been an issue. Having many cuts and folded twisted plates slows the work, but it is manageable.
I update and plot the dwgs from the DM.
AS is such a good software, they should let it stay on the market forever.
Tekla and SDS/2 have advantages, but AS has ones too.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Message 103 of 109
markhubrich
If I ever get a chance to own a water tower I already have a plan 🤣
...and fix the kiss export issues.
Message 104 of 109
bigcarl5000kg
Hi @markhubrich,
 it would also need a wind power plant, so you have a way to pump water there 😁
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 105 of 109
acbsdesign
@markhubrich
Nice one you posted above.
Message 106 of 109
markhubrich
That doesn't look like enough to fill my pool..
Message 107 of 109
acbsdesign
Pedestrian Bridge
(view in My Videos)
Message 108 of 109
acbsdesign
Another video of it:
(view in My Videos)
Message 109 of 109
mick-CNF
(view in My Videos)
If this information solves your problem please accept as a solution.
