Advance Steel Projects Gallery
MRizea
Message 1 of 109
MRizea
Hello everyone,
I was thinking that it would be a good idea to post some pictures with our projects. If it's possible, model pictures and the actual building that's been build.
I'll start...
Replies (108)
Message 21 of 109
FCort
Building
Message 22 of 109
acbsdesign
@MRizea
36 Span Pedestrian Bridge for MASSDOT,
created 3 new dwg styles for GA dwgs, and 2 new dwgs styles for MP dwgs and added the rotate and align custom command ( Screencast ) to speed up the modeling:
Pedestrian Bridge 4.jpgPedestrian Bridge 3.jpgPedestrian Bridge 2.jpgPedestrian Bridge 1.jpg
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Message 23 of 109
RyanS-SDDS
Underground Bin Lid with chutes and crusherUnderground Bin Lid with chutes and crusher6000 Ton Raw Ore bin - Underground Mine6000 Ton Raw Ore bin - Underground MineLooking down at binLooking down at bin
Message 24 of 109
Follow-up to my earlier post. Project is still under construction, modeling is nearing completion. I will post more as I receive the construction images. Just shy of 2 million pounds, all done with Autodesk products, largest cyclone in north America. Handrails in yellow for scale.
chambord overview 4.pngchambord overview 3.pngchambord overview 2.pngchambord overview 1.png
Message 25 of 109
acbsdesign
@Anonymous
Impressive work, Stephen.
Message 26 of 109
Thank you Ilko, Its a group of us here at CMA Engineering that worked on this project over the past year. I will pass on your high praise to the group. I will say this, Advance steel was a big factor in this project, automation of the drawings was a life savor. Still lots of room for improvements but still faster than detailing manually.
Message 27 of 109
TvdH1981
2019-06-28 16_15_12-Autodesk Advance Steel 2019 - [14680.dwg].png2019-06-28 16_16_26-Autodesk Advance Steel 2019 - [14680.dwg].png2019-06-28 16_30_15-Autodesk Advance Steel 2019 - [14680.dwg].png2019-06-28 16_33_51-Autodesk Advance Steel 2019 - [14680.dwg].png2019-06-28 16_42_37-Autodesk Advance Steel 2019 - [14680.dwg].png2019-06-28 16_45_08-Autodesk Advance Steel 2019 - [14680.dwg].png2019-06-28 16_48_00-Autodesk Advance Steel 2019 - [14680.dwg].png2019-06-28 16_49_19-Autodesk Advance Steel 2019 - [14680.dwg].png
Message 28 of 109
TvdH1981
Message 29 of 109
AleckGiles
Excellent project Steve & co. Good work.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
Message 30 of 109
pshtewankareem
this is one of my models that i created in advance steel
iam ready to make you shop drawings as a free lancer
mobile : 009647507041990 whats app and viber
Message 31 of 109
pshtewankareem
Message 32 of 109
pshtewankareem
WhatsApp Image 2019-11-30 at 11.50.12 AM(1).jpegWhatsApp Image 2019-11-30 at 11.50.12 AM(2).jpegWhatsApp Image 2019-11-30 at 11.50.12 AM(3).jpegWhatsApp Image 2019-11-30 at 11.50.12 AM.jpegWhatsApp Image 2019-11-30 at 12.05.15 PM.jpeg
Message 33 of 109
Sebastian_Eiche
nice project. Are you sure the bolt in the head connection could be done?  It looks like, there's not to much space.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 34 of 109
pshtewankareem
Thanks gor comment , yes offcourse
Message 35 of 109
TvdH1981
I designed a structure over an existing building of a theater. This will be used for all pullysystems to hoist the decors and sorts. Also included to levels with gratings on it. So there can be maintanance up there. We try to built as efficient as possible and create as much as the same connections if possible.Pic01.pngPic02.pngPic03.pngPic04.pngPic05.pngPic06.png
Message 36 of 109
aelmay
☆SILO TRANSPORT PETCOKE☆
☆Location:Tunisia
☆Weight: 140 T
Message 37 of 109
aelmay
silo transport petckoke
Message 38 of 109
acbsdesign
Used Shared Views for a few:
Bridge 01.collaboration (1).pngBridge 01.collaboration (2).pngBridge 01.collaboration (3).pngBridge 01.collaboration.pngBridge 04.collaboration (4).pngBridge 011A.collaboration (1).pngBridge 011A.collaboration (2).pngBridge 011A.collaboration (3).pngBridge 011A.collaboration.pngBuilding 001 .jpgBuilding 01.collaboration (6).pngBuilding 004.pngBuilding 019A.collaboration (1).pngBuilding 019A.collaboration (2).pngBuilding 019A.collaboration.pngCrane Boom 01.collaboration (2).pngCrane Boom 01.collaboration.pngDOCK 02.collaboration.pngMisc 01.collaboration (2).pngMisc 01.collaboration (4).pngMisc 01.collaboration.pngModel Export 001.collaboration (1).pngModel Export 001.collaboration (2).pngModel Export 001.collaboration (3).pngModel Export 001.collaboration (4).pngModel Export 001.collaboration.pngPlatform 0324.collaboration.pngPlatforms 2.collaboration (1).pngPlatforms 2.collaboration (2).pngPlatforms 2.collaboration.pngPlatforms 011.collaboration (1).pngPlatforms 012.collaboration (3).pngPlatforms 012.collaboration (4).pngRR Bridge 001.collaboration (2).pngRR Bridge 001.collaboration (3).pngRR Bridge 001.collaboration (4).pngRR Bridge 001.collaboration (5).pngRR Bridge 001.collaboration.pngRR Bridge 002.jpgRR Bridge 003.collaboration (1).pngRR Bridge 003.collaboration (2).pngRR Bridge 003.collaboration (3).pngRR Bridge 003.collaboration (4).pngRR Bridge 003.collaboration (5).pngRR Bridge 003.collaboration.pngShared Views Walkways  001A.collaboration.pngShared Views Walkways  001B.collaboration (1).pngShared Views Walkways  001B.collaboration (2).pngShared Views Walkways  001B.collaboration.pngSupport Steel 1.png
Message 39 of 109
S.MANICKAVASAGAM
Dear Expert,
               All are nice, keep it up.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
My body Your body Every body is Just SOIL body
Message 40 of 109
acbsdesign
A few bridges, used Shared Views, sometimes people do not realize the complexity of bridge geometry, a single-span bridge looks simple, it is not, wish I had real nice real-world pictures of them, lol:
Bridge MASSDOT 4-01b1aA.jpgBridge MASSDOT 4-01b3a.jpgBridge MASSDOT 4-01ba.jpgBridge MDOT 4-02.jpgBridge MDOT 4-03.jpgBridge MDOT 4-03ajpg.jpgMassDOT 04 17 2 na .jpgMassDOT 04 17 2 nb .jpgMassDOT 04 17 2 nv .jpgMassDOT 04 17 2 nwa .jpg
