@AzzaRazzamataz wrote:
Current laptop is the HP ZBook 14u G5 with extra ram added (32gb total).
Drivers are all updated and performance tweaks made to Windows & Autodesk products.
Latest services packs & hot fixes installed for 2019 & 2020.
Advance Steel doesn't run that great on them. Tried Advance Steel 2019 & 2020 for two different users (same machines) both crash quiet regularly where the models are currently only small.
Even plane old 2D AutoCAD runs a bit jumpy.
As the others said-it is hard to believe this is a video card issue. Unless it is defective and if it is-call HP, they will take care of it.
I have a similar HP Z G17 4K and it runs great for a laptop,
not a BOXX product, but it does the job even with 1,000,000+ pounds projects when away from my place.
Best I would recommend is call HP, even if you don't have a warranty left, pay a small fee, they are pretty good and responsive.
But in no case spend extra $$$ for eGPU if you run only AS2020.
Have a great day.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
