Advance steel not starting
Message 1 of 10
I installed the Advance Steel 30 day trial but I can't start the program. When I click on the icon nothing is happening.
Replies (9)
Message 2 of 10
Ok, I fixed it by reinstalling Autocad 2015 trial.
Message 3 of 10
Tioneb003
Dominic,
As you would like to know Advance Steel is an add-on to AutoCAD so if you dont have any up to date versions of AutoCAD Advance Steel wont start..You can run the trial version of AutoCAD to run the trial of Advance Steel.
Install of AutoCAD trial : http://www.autodesk.ca/en/products/autocad/free-trial
Feel free to contact me directly im working at Graitec as a technical specialist for Advance Steel. Graitec is an official reseller for the Advance Steel product and you can be served in English or French. 1-800-724-5678 ext.240 [email protected]
Benoit Lalonde
Message 4 of 10
Hi
I tried down loading the advanced steel software it failed to run, I got an error message that the key was not recognised, does it mean i also have toreinstall my revit student.
thanks
rt
Message 5 of 10
muleman1
Help Menu not working
@DominicBeauchamp
Dom please use the link above to see the discussion about the help menu. Do you know of a fix for this?
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
Message 6 of 10
muleman1
sorry the question above should have been
@Tioneb003
Message 7 of 10
mjoflor
hi i have the follow trouble whe i try to put the product key it said it is not valid, can you help me please
Message 8 of 10
joane.bonghanoy
Hi @mjoflor,
I'm making an assumption you are trying to install Autodesk Advance Steel 2015, Product Key is 959G1. However if you do have Autodesk Advance Steel 2015 with AutoCAD Product Key is 958G1.
Click here for details on Autodesk Product Keys for 2015
Joane Bonghanoy
Message 9 of 10
Hi mjoflor,
The current updated Advance Steel Trial download now appears to be version 2015.1 in which case you will need to use product code 958G2
Hope this helps.
Geoff.
Message 10 of 10
limezestpizzawithextracheese
Hi, I have autocad architecture version installed on the computer and i just installed the Advanced steel, but it does not work. It gives the same error ! Do i really have to install autocad (alone) ?
Deniz
