Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Advance Steel .NET API Walkthroughs are now available!
36 REPLIES 36
Message 1 of 37
manolic
6003 Views, 36 Replies
Hello Everyone,
New Advance Steel .NET API walkthroughs are now available here
Cosmin Manoliu
Senior Manager, Engineering
36 REPLIES 36
Message 2 of 37
ChristianBlei
in reply to: manolic
And where is here?
BR, Christian Blei
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
Message 3 of 37
muleman1
in reply to: ChristianBlei
http://help.autodesk.com/view/ADSTPR/2016/ENU/?guid=GUID-15154F08-0BE8-4547-B94A-ACA8D284E219   @ChristianBlei
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
Message 4 of 37
manolic
If you wonder how to use together AutoCAD and Advance Steel API, you might find useful the new walthrough:
http://help.autodesk.com/view/ADSTPR/2016/ENU/?guid=GUID-0AFEFD2B-EED4-4F6A-8F97-BA0814E99643
Cosmin Manoliu
Message 5 of 37
phliberato
In the Code Region "Selecting a beam" there is a problem. I can't convert Intptr(id.OldIdPtr) to AcDbObjectId*. How can I fix it?
ASObjectId idDbObject = DatabaseManager.GetFilerObjectId(new ASObjectId(id.OldIdPtr), false);
Message 6 of 37
ChristianBlei
in reply to: phliberato
what about
Dim tObJId As New DatabaseServices.ObjectId(id.OldIdPtr)?
BR,
Christian Blei
Christian Blei
christianblei.de
Message 7 of 37
ChristianBlei
this is the metadata for CadLink.DataBase.ObjectId
Namespace Autodesk.AdvanceSteel.CADLink.Database
Public Class ObjectId
Implements IDisposable
Public Sub New(other As ObjectId)
Public Shared ReadOnly Property kNull As ObjectId
Public NotOverridable Overrides Sub Dispose()
Protected Overridable Sub Dispose(A_0 As Boolean)
Public Function AsOldId() As IntPtr
Public Overridable Function Equals(obj As ObjectId) As Boolean
Public Function IsNull() As Boolean
Public Shared Operator =(obj1 As ObjectId, obj2 As ObjectId) As Boolean
End Class
End Namespace
The argument in New(other As ObjectId ) does not make sense to me- it is creating a circular definition.
Sub New should take a System.IntPtr as argument.
Function .AsOldId is returning a System.IntPtr !!!!!!!
BR,
Christian Blei
Christian Blei
christianblei.de
Message 8 of 37
ChristianBlei
You can use the AcObjId.Handle.ToString to access the filerobject
Dim tHandle As String = tAcObjId.Handle.ToString()
Dim tObj As FilerObject = FilerObject.GetFilerObjectByHandle(tHandle)
BR,
Christian Blei
Christian Blei
christianblei.de
Message 9 of 37
ChristianBlei
Sorry.
I checked
Dim tObjId as Autodesk.Autocad.Databaseservices.ObjectId= nothing
Dim tHandle As String = tObjId.Handle.ToString()
The filermethod .GetFilerObjectByHandle throws an exception.
I am curious what the Advance API developers will comment.
BR,
Christian Blei
Christian Blei
christianblei.de
Message 10 of 37
ChristianBlei
I did some tests. The AutoCad Entity and the advance object have sequencing handles (or ObjIds). The question is, where is the connecting property.........
BR,
Christian Blei
Christian Blei
christianblei.de
Message 11 of 37
manolic
The problem with Advance Steel ObjectId not accepting a constructor argument of type IntPtr probably comes from the fact that you are not using Advance Steel 2016 R2 API.
Cosmin Manoliu
Message 12 of 37
ChristianBlei
Hello Cosmin,
I will immediately install the AS2016 R2.....
and the update did it.
BR,
Christian
Christian Blei
christianblei.de
Message 13 of 37
phliberato
Thanks @ChristianBlei and @manolic for your support.
I have the AS2016 Hotfix 1, but I didn't see AS2016 R2 in Application Manager.
Can somebody send me a link for download?
Message 14 of 37
phliberato
I did the update! Thank you!
Message 15 of 37
ChristianBlei
hello
You are welcome!
You will find the update in your account. There are two updates to download, one about 500MB, the other about 7MB.
The link is:
https://manage.autodesk.com/cep/#products-services/updates
BR,
Christian Blei
Christian Blei
christianblei.de
Message 16 of 37
manolic
Message 17 of 37
ChristianBlei
Hi Cosmin,
for me none of the hyperlinks is working.
Is it my problem or a general, would you please check?
br,
Christian Blei
Christian Blei
christianblei.de
Message 19 of 37
any Developer Training guide and Reference guide on AS2017 api? downloadable?
Message 20 of 37
Here we are a year later, but I have to reask - any information on the 2017 API? Guide? Walkthroughs?
