When importing a structure from advance steel to revit I encounter an error after loading all of the corresponding parts. when the structure is remade just with structural columns and beams it will load without a problem. Trying to figure out where my hang up is.
can you attach the .smlx file so i can test?
Thank you, Here is the file I was attempting to use. I had to zip it because it is saying smlx is not supported.
