So I have advanced Steel model, classic problem where I don't want material take off by the type but I want for each part or it can be multiple instance of same type object. So inbuilt function of advanced steel option to create BOM/ metal takeoff , creates it with by type as a total, but I want for each instance.
1) i want loop through each object, i am not able to do that need help in this regard ****
2) read their properties
3) then write all in excel (i can do)
Solved by cristian.udreaBYPDW. Go to Solution.
Solved by george1985. Go to Solution.
1) Obtain ids of all Advance Steel objects:
Autodesk.AdvanceSteel.CADAccess.DatabaseManager.GetModelObjectIds()
Get their objects:
Autodesk.AdvanceSteel.CADAccess.DatabaseManager.Open()
For this step, you would need to call upper Open method inside DocumentAccess. See the example in SDK documentation for NET API:
https://help.autodesk.com/view/ADSTPR/2022/ENU/?guid=GUID-19A366F0-C51F-45AB-AF0C-46E59ABFD284
2) Set up a debugger breakpoint in Visual Studio. Most properties are self-explanatory: ASobj.Material, Asobj.Coating, ASobj.Layer...
I want to create very custom BOM where objects with same attributes are Counted , I have been succeeded, in finding all the objects types such as Beams, Plates, Bolt Patterns etc. but not able to do it with Washers and nuts
While Creating BOMs Manually you can find Washers and Nuts but not in API,
Creating Manual BOM , is not an option as i want to sort them based on user attribute
are washer/nut filer object , do they have objectId or no?
Hi @official.jaydeo ,
Yes, as far as I know, washers and nuts have no objectId.
You would have to calculate them based on the ".Assembly" property of the bolt pattern object.
Example:
"NaW" - 1 x nut, 1 x washer
"Na2W" - 1 x nut, 2 x washer
I want to access their weight, is there any way we could know what washer /nut are used for BoltPatterns
@cristian.udreaBYPDW @ChristianBlei @dragos.olaru @mihaido @NinovSM
The class Autodesk.AdvanceSteel.Modelling.ScrewBoltPattern has a GetWeight() method.
This extends to all inheriting classes: AnchorPattern, CircleScrewBoltPattern, CountableScrewBoltPattern, FinitRectScrewBoltPattern,
InfinitMidScrewBoltPattern and InfinitRectScrewBoltPattern.
This method will return the weight for the whole set of Bolts/Screws/Nuts/Anchors.
Let's assume a bolt pattern was created like in this example:
FinitRectScrewBoltPattern boltPattern = null; // reference to the bolt pattern for later
using (DocumentAccess da = new DocumentAccess())
// build an "objects to connect" array
FilerObject[] objectsToConnect = new FilerObject[1];
objectsToConnect[0] = plate; // we assume an existing plate, that was previously created
// create a standard rectangular pattern set of bolts
boltPattern = Utilities.CreateFinitRectScrewBoltPattern(new Point3d(-100, -100, 0), new Point3d(100, 100, 0), new Vector3d(1, 0, 0), new Vector3d(0, 1, 0));
// connect the objects
boltPattern.Connect(objectsToConnect, AtomicElement.eAssemblyLocation.kOnSite);
// set a valid combination of properties
// check table "ScrewNew" from "AstorBase.mdb" for valid combinations
boltPattern.Standard = "14399-4";
boltPattern.Grade = "10.9";
boltPattern.BoltAssembly = "Mu2S";
boltPattern.ScrewDiameter = 16;
da.Commit();
GetWeight can be called like this, further divided by the number of screws to get the weight of each screw:
using(DocumentAccess da = new DocumentAccess())
double boltPatWeight = boltPattern.GetWeight() / 1000;
double singleWeight = boltPatWeight / boltPattern.NumberOfScrews;
If you want this split down even further, there is no specific API for it as of now.
Instead, you must add references to ASDataObjects.dll and ASRepository.dll and query the database in 2 steps:
The first step is to get the specific SetOfBolt for your ScrewBoltPattern. Replace with AnchorsName if it's an AnchorPattern instead.
using ASRepository;
using ASDataObjects.AstorBase;
using ASRepository.Criteria;
SetOfBolt[] arrSetOfBolts = null;
using (var repo = RepositoryFactory.GetRepository<SetOfBolt>(eDatabase.kBase, -1))
var select = new SelByMultipleProps<SetOfBolt>(
new string[] { nameof(SetOfBolt.Standard), nameof(SetOfBolt.Material), nameof(SetOfBolt.Diameter) },
new object[] { boltPattern.Standard, boltPattern.Material, boltPattern.ScrewDiameter });
arrSetOfBolts = Enumerable.ToArray(repo.Select(select));
The second step is to iterate over the pattern's specific SetOfBolt and get the corresponding SetNutsBolt of every item, which is the data from the table in your screenshot.
SetOfBolt setOfBolt = arrSetOfBolts[0];
using (var repo = RepositoryFactory.GetRepository<SetNutsBolt>(eDatabase.kBase, -1))
for (int i = 1; i <= setOfBolt.Length; ++i)
var setOfBoltType = typeof(SetOfBolt);
string Standard = (string)setOfBoltType.GetProperty($"DIN{i}").GetValue(setOfBolt);
double Diameter =(double)setOfBoltType.GetProperty($"Diameter{i}__mm_").GetValue(setOfBolt);
string Material = (string)setOfBoltType.GetProperty($"Material{i}").GetValue(setOfBolt);
var select = new SelByMultipleProps<SetNutsBolt>(
new string[] { nameof(SetNutsBolt.Standard), nameof(SetNutsBolt.Material), nameof(SetNutsBolt.Diameter) },
new object[] { Standard, Material, Diameter });
SetNutsBolt[] partOfBolt = Enumerable.ToArray(repo.Select(select));
// THIS is the weight of each piece of a bolt
double partWeight = partOfBolt[0].Weight.GetValueOrDefault();
Sorry i did not get , how can i access Washer/Nut Properties from above code,
let me tell you what i know
I am getting all the Screw Bolts from project using this,
Autodesk.AdvanceSteel.CADLink.Database.ObjectId[] objectIds = null;
DatabaseManager.GetModelObjectIds(out objectIds);
then i am checking if it is BoltPattern
then i am getting screw properties
if (steelObject is Autodesk.AdvanceSteel.Modelling.BoltPattern BoltPattern1)
BoltPattern_Coll.Add(BoltPattern1);
foreach (BoltPattern ty in BoltPattern_Coll)
sw.WriteLine($"{0},{"Bolt " + ty.GetName(out v)},,
{UnitConverter1.ConvertMillimetersToFeetInches(ty.ScrewLength)},
{ConvertGramsToDecimalPounds(ty.GetWeight() *
ty.NumberOfScrews).ToString("F2")},{ty.NumberOfScrews},{ty.Material} ,{ty.GetUserAttribute(UserAttributeint)}");
now how do i get type of washer used in this Bolt pattern and its weight, and all of it's Possible Properties....... @cristian.udreaBYPDW @ChristianBlei @george1985
Hi @official.jaydeo,
Instead of Autodesk.AdvanceSteel.Modelling.BoltPattern please use the object class Autodesk.AdvanceSteel.Modelling.ScrewBoltPattern so that all the Bolt Pattern properties that are required to interrogate the database are available.
Then, to get the washer, nut, peg, etc. properties, adapt the code from my previous post to your particular situation.
AS.NET API does not publish methods or properties to get the Nut/Washer/Peg properties.
Instead the database must be interrogated to get these values.
The changed code would look similar to the following :
using ASRepository;
if (steelObject is Autodesk.AdvanceSteel.Modelling.ScrewBoltPattern screwBoltPat)
ScrewBoltPattern_Coll.Add(screwBoltPat);
foreach (ScrewBoltPattern screwBoltPat in ScrewBoltPattern_Coll)
// Get the representation of a screw or bolt in the database
var dbSelect = new SelByMultipleProps<SetOfBolt>(
new object[] { screwBoltPat.Standard, screwBoltPat.Material, screwBoltPat.ScrewDiameter });
arrSetOfBolts = Enumerable.ToArray(repo.Select(dbSelect));
// Iterate the set of Peg/Nut/Washer parts
// setOfBolt.Length is how many parts there are to a bolt, such as a nut a peg or a washer
// Interrogate the database again, this time for each individual part of the bolt
// partOfBolt[0] might be a nut, a peg or a washer depending on the Type property
// 1 is for Nut, 2 is for Washer, 3 is for Peg
int partType = partOfBolt[0].Type.GetValueOrDefault();
// This is the weight of each piece of a bolt or screw (e.g. a nut or a washer)
// or other properties like
double partHeight = partOfBolt[0].Height.GetValueOrDefault();
int partNocorners = partOfBolt[0].NumberOfCorners.GetValueOrDefault();
// etc.
i was able to find bolts in database using setBolts, how do i find Anchors? i could not find any class
@official.jaydeo For Anchors the same information (Nuts and Washers) can be found in the structure AnchorsName.
The code to access Anchor information is similar to the one used to access the Bolts information, with a few class and property changes. The object class is Autodesk.AdvanceSteel.Modelling.AnchorPattern and the changed code would look similar to the following:
using ASRepository;
if (steelObject is Autodesk.AdvanceSteel.Modelling.AnchorPattern anchorPat)
AnchorPattern_Coll.Add(anchorPat);
foreach (AnchorPattern anchorPat in AnchorPattern_Coll)
// Get the Anchor definition
AnchorsName[] arrAnchorDefs = null;
using (var repo = RepositoryFactory.GetRepository<AnchorsName>(eDatabase.kBase, -1))
var selAnchorDef = new SelByMultipleProps<AnchorsName>(
new string[] { nameof(AnchorsName.Standard), nameof(AnchorsName.MaterialKey), nameof(AnchorsName.Diameter), nameof(AnchorsName.SetName) },
new object[] { anchorPat.Standard, anchorPat.Material, anchorPat.ScrewDiameter, anchorPat.BoltAssembly });
arrAnchorDefs = Enumerable.ToArray(repo.Select(selAnchorDef));
// Iterate the set of Nut/Washer parts of the Anchor
AnchorsName anchorParts = arrAnchorDefs[0];
// anchorParts.Length is how many parts there are to an anchor, such as a nut or a washer
for (int i = 1; i <= anchorParts.NumItems; ++i)
var anchorDefType = typeof(AnchorsName);
string Standard = (string)anchorDefType.GetProperty($"DIN{i}").GetValue(anchorParts);
double Diameter = (double)anchorDefType.GetProperty($"Diameter{i}").GetValue(anchorParts);
string Material = (string)anchorDefType.GetProperty($"Material{i}").GetValue(anchorParts);
// partOfBolt[0] might be a nut or a washer depending on the Type property
// This is the weight of each piece of an anchor (e.g. a nut or a washer)
// etc.
The different anchor definitions for each one specific anchor type can be found in the structure AnchorsDefinition, based on AnchorsName.ID and accessed similar to the following:
AnchorsDefinition[] anchorsDefinitions = null;
using (var repo = RepositoryFactory.GetRepository<AnchorsDefinition>(eDatabase.kBase, -1))
var selAssy = new SelByPropValue<AnchorsDefinition, int>(nameof(AnchorsDefinition.AnchorID), anchorParts.ID);
anchorsDefinitions = Enumerable.ToArray(repo.Select(selAssy));
If the database query succeeds, anchorsDefinitions now contains all the different anchor definitions for this one specific anchor type similar to the Database Management tool.
