Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Advance Steel 2023, Line, Pline, Dimlin not working/visible?
1 REPLY 1
224 Views, 1 Reply
Line or Pline command not working, I don't see anything as I click (though it asks for a second point) and it doesn't seem to actually make a line, because I left drag over the area after and I still don't select anything.
Dimlin is similar, except it seems to actually make the dimension, but I can only see a tiny dot.
Just upgraded to a new computer, upgraded to Advance Steel 2023.  Can't seem to find too much that relates to this, even in AutoCAD forum. Messed with graphics config, line type and weight, that's about it, no luck.
Attached a file I'm working on and some screen shots.
Any help is appreciated.
Tags (4)
1 REPLY 1
iwafb
iwafb
Please check your current layer is not off...
