Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Advance Steel 2019 API Selection method
4 REPLIES 4
NinovSM
964 Views, 4 Replies
NinovSM
This simple C# code returns null for "ASobject" variable in AS2019. In previous AS versions works correctly.
Autodesk.AdvanceSteel.CADLink.Database.ObjectId objId = UserInteraction.SelectObject();
AtomicElement ASobject = DatabaseManager.Open(objId) as AtomicElement;
 What is the reason?
 What is the reason?
4 REPLIES 4
ChristianBlei
in reply to: NinovSM
ChristianBlei
startoing in AS 2019 you need to start a transaction and access objects inside of a transaction. Before AS2019 with the calling of an Advance Steel API command implicitly a transaction was started at command start and committed at command and. That is now up to you. So use code like
    Public Shared Sub GetReprType()
        Dim tObjId As ObjectId = UserInteraction.SelectObject
        If tObjId IsNot Nothing Then
            DocumentManager.LockCurrentDocument()
            Using tTrans As Transaction = TransactionManager.StartTransaction
                Try
                    Dim tFilerObj As FilerObject = DatabaseManager.Open(tObjId)
                    Dim tReprObjId As ObjectId = DatabaseManager.GetReprId(tFilerObj)
                    Dim tAcObjId As New DatabaseServices.ObjectId(tReprObjId.AsOldId)
                    Dim tReprName As String = tAcObjId.ObjectClass.Name
                    Debug.Print("")
                    MsgBox(tReprName)
                Catch ex As Exception
                Finally
                    tTrans.Commit()
                End Try
            End Using
            DocumentManager.UnlockCurrentDocument()
        End If
    End Sub
By the way: If you select Acad entities with userinteraction metrhod, their ADVS ObjectId will be null.
HTH,
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
                Try
                    Debug.Print("")
                    MsgBox(tReprName)
                Finally
                    tTrans.Commit()
                End Try
            End Using
        End If
    End Sub
HTH,
Christian Blei
christianblei.de
NinovSM
in reply to: ChristianBlei
NinovSM
Hi, Christian
Thanks for answer.
But as I know your code for VB.NET. My question about C#
Hi, Christian
Thanks for answer.
ChristianBlei
ChristianBlei
there are code translators, that you can find in the net that help to translate between VB and C#.
The code inC# would be like
    class Test
        public static void GetAtom()
            ObjectId tObjId = UserInteraction.SelectObject();
            if (tObjId.IsNull()== false)
                DocumentManager.LockCurrentDocument();
                using  (Transaction tTrans = TransactionManager.StartTransaction())
                    try
                        FilerObject tFilerObj = DatabaseManager.Open(tObjId);
                        if (tFilerObj.IsKindOf(FilerObject.eObjectType.kAtomicElem))
                            AtomicElement tAtom = (AtomicElement)tFilerObj;
                    catch (Exception ex)
                    finally
                        tTrans.Commit();
                DocumentManager.UnlockCurrentDocument();
HTH,
Christian Blei
christianblei.de
Christian Blei
christianblei.de
    class Test
                    try
                    finally
                        tTrans.Commit();
HTH,
Christian Blei
christianblei.de
Christian Blei
christianblei.de
NinovSM
