Dear
I am not sure you have 64 bit OS...this message is classic when you try to install 64 bit in a 32 bit. In order to have total certain about it, press the windows flag button in your keyboard and type "dxdiag" confirm and all the information about your PC will appear in a window...
Well, return to website and download the suitable version for your machine...
I hope have to helped you...
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
