Announcements
Adjust section name distance
Hello everyone,
Where can I adjust the distance between the section name and the detail? Is there somewhere a variable which control that ?
Picture added to better understand the question.
Jonathan.Jasinski
I don't think that there is a place to set that default other than a general "Bottom" or "Top Right" position (There are more than that, but you get my point).  That being said, the titles are movable with a simple move command or grip edit.
Hi Jonathan!
I know, I can move tham easily but, I want to get those titles closer to the detail when the detail is generated. There's a lot of system variable in the databases, there have to be one, that controls the distance 🙂
So any other suggestions ?
Dias_Antonio
Hey pal
By the way, have you already tried to drag to the nearest position you want?
Do you want to do with the all dimensions or just one?
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
Maybe I wasnt clear enough.
I want to set the distance X in a AS system variable, to get closer the detail title to the section detail.
Not to drag and move, but set the value, and get the right distance after I made the assembly drawing from a beam or a column.
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi ztn.design.mi
The distance you are trying to change - distance between title text and view elements - is hard-coded to 10 mm.
There is no option to modify it at this moment. Sorry to tell you this.
If you want, you may create a feature request on the Advance Steel Idea Station portal. In this way other users are able to contribute and vote for your idea, while the management team is actively monitoring this portal.
At this moment, as you already know, you have the option to move the title manually, after creating the detail. And the move should be kept in case of detail update.
Best regards,
Emy
Emy Nestor
Thank you Emy.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
