Adding an object to a bolted rule controlled element
05:09 AM
Is there anyway to add the bolts of a rule controlled element to a secondary beam or object that just happens to coincide with the bolts of a rule controlled element?
For example i have a set of stair stringers that have the treads bolted into the sides of the stringers. I am attaching a beam to the stringers that just happens to cross the bolt set that connects a tread to the stringer. If i use the add 'add connection object' tool, it won't let me connect the beam to the stringer using the tread bolts because its a 'rule controlled element'.
Is there any way around this?
