Hi All,
Finally decided to push myself to expand from LISP and try my hand at VB.NET.
To that end, I'd simply like to add a polyline to the model. I've defined it, but can't find how to commit the object to the database (apologies, I'm sure I'm using all the wrong terms...)
I've got:
'Define polyline
For i As Integer = 0 To arraylist.Count - 1
polyline.Append(arraylist(i))
Next
I was hoping to be able to use the AS API something like
polyline.WriteToDb()
But obviously it doesn't work.
Is there a way to use the AS api to add the polyline to the model (seems simpler that the ACAD api) or do I have to cross over between the two?
Hope that makes sense and thanks in advance.
Solved by NinovSM. Go to Solution.
You should use Autocad API for that. You can use AS & ACAD API at the same time but in different transactions.
