add diameter to Anchor
GHASEM_ARIYANI
Advisor Advisor
GHASEM_ARIYANI
hi
How do I add diameter to Anchor in the LIST?
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Buxtehude1963
you have create a new anchor bolt with your diameter in the  anchors database.
This link can help you
https://screencast.autodesk.com/Main/Details/a5cb1024-2011-4c75-aa92-e9df5df84fa4
Regards
GHASEM_ARIYANI
How do I set the diameter in mm?
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Bogdan.O
  1. In Management Tools, close the Anchors tab then go from the Home tab to Units.
  2. Change the Scale unit to Milimeter and set the Format and Precision.
  3. Click Apply and reopen the Anchor tab to see the units changed.
Bogdan Orzea
QA Analyst
GHASEM_ARIYANI
Hello
Thank
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
GHASEM_ARIYANI
hi
I ran into a few problems.
I want to make it like the picture below.
problems? but.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
