Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
ADD ARROW ON LABEL AND WELD SYMBOLE
4 REPLIES 4
Johnnj1010
828 Views, 4 Replies
Hi everyone
I hope someone can explain me if it's possible to add a few arrow on a label or on a weld symbol without do a copy and just put it above.
Thanks for your time.
Jean
Tags (3)
4 REPLIES 4
Rob_Merriman
in reply to: Johnnj1010
Hi @Johnnj1010
Do you want to add extra lines to existing labels / welds like shown in the screenshot below?
If this is the case unfortunalty this isnt possible as far as I am aware
Rob Merriman, AEC Technical Lead, Graitec
Johnnj1010
in reply to: Rob_Merriman
Thanks Rob
 Yes this is what I mean.
Ok perfect its not possible.
Thanks for your quick answer.
select the weld symbol...right click...pick add leader line
this working now, but in the starting of this thread, this feature was not existing
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
