Access Token in Advance Steel API
chockalingam
chockalingam
I am new to advance steel API
I want to get the Object Top Level (from token) through API.
Someone please guide me in acheiving this.
Thanks in advance.
Chockalingam
turbatc
I am not sure I understood correct what exactly means "Object Top Level (from token)"?
Could you please give me more details about that?
Constantin
Constantin T
Principal Engineer
chockalingam
In Advance steel when i double click the label, there is a option to select "Object Top Level" for label content.
I want to access that object through API.
I hope i explained my requirement clearly this time.
Chockalingam
turbatc
Currently, it is not possible to access the detail object through the API.
We will add an issue to make this workflow possible in the future.
A workaround will be to get the extents from the model object then calculate the bottom and the top level.
Sample code:
Autodesk.AdvanceSteel.DocumentManagement.DocumentManager.lockCurrentDocument();
Autodesk.AdvanceSteel.CADAccess.TransactionManager.startTransaction();
Autodesk.AdvanceSteel.CADLink.Database.ObjectId objectId = UserInteraction.SelectObject();
FilerObject pObject = DatabaseManager.Open(objectId);
if(pObject.IsKindOf(FilerObject.eObjectType.kAtomicElem))
	AtomicElement pAtomic = (pObject as AtomicElement);
	Autodesk.AdvanceSteel.Geometry.Point3d minPoint = pAtomic.GeomExtents.MinPoint;
	Autodesk.AdvanceSteel.Geometry.Point3d maxPoint = pAtomic.GeomExtents.MaxPoint;
	double objectBottomLevel = minPoint.z;
	double objectTopLevel = maxPoint.z;
Autodesk.AdvanceSteel.CADAccess.TransactionManager.endTransaction();
Autodesk.AdvanceSteel.DocumentManagement.DocumentManager.unlockCurrentDocument();
Constantin T
Principal Engineer
chockalingam
Hi Constantin T,
Thanks for your reply.
DatabaseManager.Open(objectId) is always returning null for me.
I am trying to select the object inside the view box in drawing.
Is there any way to overcome this issue.
Thanks in advace.
Chockalingam.
turbatc
Currently Advance Steel API supports only model objects.
You cannot access the objects from a detail drawing.
Constantin T
Principal Engineer
