u can set the material for plate to durbar plate
if u dont like durbar plate name ,u may be abil to edit sum table in manager to add checker plate to the material list
u can see in pic the bom has material as durbar plate
u could edit drawing proces /tital of detail , to add material to name under part on drawing
S. Lapointe,
You may already be aware that checker plate is located under grating. This is so you can nominate the side the pattern is on. The down side is that you cannot fold grating, therefore it is impossible to create folded checker plate in Advance Steel. This needs to be addressed by Autodesk. I notice 5/16" checker plate is not included in the list under USA - Checker Plate. You can add it into the database by copying a line and changing the details.
John Stewart.
i never know that
the grating cheker looks a lot better , more like cheker
but the plate way is easier to give it a thickness and as u sed u can do folds
