Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
3D Model Total Weight
9 REPLIES 9
Message 1 of 10
atelier.absinthe
3699 Views, 9 Replies
atelier.absinthe
Hi guys,
the command is "CENTER OF GRAVITY and TOTAL WEIGHT CALCULATION"
first: is there a list, an online guide, help, something that specifically indicates what is being considered and how to calculate the weights of the complete 3D model?
second: Are the bolts weighed?
Can the welds be weighed?
I tried on the HELP guide, on the forum but I did not find any answer about it!
Thanx all!!
d.
Facchetti Davide - www.studiofacchetti.com
Davide Facchetti | Architect | Studio FACCHETTI | Bergamo - IT
Hi guys,
Thanx all!!
d.
9 REPLIES 9
Message 2 of 10
Sebastian_Eiche
I don't know if there's a documentation, but I could say: bolts and weld are not implemented.
To get the weight of the model with bolts--> use a material BOM list and use the token for the total weight.
Weld could not be shown, because the modelobject have no weight (it's only a line in the model). But the most just use the function to calculate maybe 5% of the total weight.
regards
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
regards
Sebastian Eiche
Message 3 of 10
atelier.absinthe
Thanks for the reply! even if unhappy! 🙂
Message 4 of 10
in reply to: Sebastian_Eiche
Can you show show how to calculate that 5% of total weight of the project in BOM? Thanks
Message 5 of 10
Sebastian_Eiche
Sebastian_Eiche
I'm not in the office for a few days, but if you have look here in the forum or just in the Autodesk Knowledge you will find a few article for calculating in bom editor.
You had to insert a new field and then calculate the weight*1,05.
I could give you some pics if you wait a few days 🙂
Sebastian Eiche
Sebastian Eiche
Message 6 of 10
But when I write that kind of formula it calculates for every element. I want want to calculate 5% of total weight of the project at the end of bom
Message 7 of 10
Sebastian_Eiche
Sebastian_Eiche
For summarize the total weight, it is necessary to have this fields, because if the weight is not calculated it could not be summarised.
You could set the field to 'not visible' in the properties on the right side. Then summarize it and only let this field to be shown.
Sebastian Eiche
Sebastian Eiche
Message 8 of 10
I tried this, but i dont get how to summarise fields. 😞
Message 9 of 10
Sebastian_Eiche
Sebastian_Eiche
If you have a look in the autodesk knowledge you will find an article belonging to this. I'm on with phone so I only find the German article for it, should be similar one if have a look for it...
https://knowledge.autodesk.com/de/support/advance-steel/troubleshooting/caas/sfdcarticles/sfdcarticl...
Sebastian Eiche
Sebastian Eiche
Message 10 of 10
You are my hero for today. Spent more than hour at work without any
results. Thank you very much. I will try it tommorow. Google translates
from german to english quite good. Best wishes from Lithuania 😉
