- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In advance steel, its very advantageous to draw while using 2D-wireframe, as this allows the user to select center lines, corners on the opposite side of beams etc...
The downside of this is that the performance is very limited, which becomes apparent in larger models. When rotating, the program has to switch to a 3D-view, as rotating is performed within the 3D-space, and then switch back to 2D-wireframe. This is makes model almost completely unusable if the model is moderately large and has a couple of xrefs attached.
I've tried customizing my own 3D-wireframe viewmode, show occluded lines and all that (basically i followd this guide). Which looks good at a first glance but the utility of selecting occluded lines, such as center lines or opposite corners, is lost.
Is there a way to customize the 3D-wireframe viewmode to allow me to select the occluded lines?
