Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
ProEst (and Estimate) feature request: Takeoff
To be able to use a surface AND the perimeter as an automatic parameter in an assembly.  When we do a takeoff of a surface, the system also calculates the perimeter. If I create an assembly and set "surface," I will need to point to the surface on the plan, but the software cannot automatically extract the perimeter to use it in the same assembly.
Example: Formwork for a structural slab. I would point to the surface, give it the thickness, and it would calculate the formwork below and the entire perimeter in the same assembly.
2 Comments
L_renz00
Observer
Create a formula variable called "AreaPerimeter" spell it exactly the same way (w/o quotations), set the variable unit to LF and input to Digital. When you are creating the assembly use that variable to pull the perimeter takeoff from the area takeoff so you can use it for calculations.
fmercier_lintendant
Hi, It is a good idea and I will do that. Thanks,
