Similar to how the Build Module allows you to search content inside of a PDF to populate sheet numbers and descriptions would be great to carry into Docs and allow that data to be recognized and linked to a custom attribute. An example would be where removing a PDF sheet description from the file name and adding it to a custom attribute under description. This would help reduce long files names. Another idea would be to read a Revision area on a titleblock and apply that revision delta number or letter into a custom attribute allowing us to know what revision that sheet is without having to view it. Thank you
