Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Multiple Feature Requests for General functionality
  1. Desktop Connector
  • Ability to open desktop connector without it being pinned to screen. It cannot go to background or be moved without it closing. Also would like notifications on syncing errors since they're so frequent.
  • Not backlogging syncs when there is 1 error 'in front'. Just skip the error and keep going.
  • Better syncing between connector & Browser
  1. iPad App
  • Ability to make updating comments on room status from app. This is only available in the web browser.
  • Easier way to 'drop tool' in iPad app.
  • Creating Tasks > Direct link for photos not all 2nd selection screen. If need edits, person should go back in. Like PlanGrid.
  • Ability to ZOOM camera out. When taking photos in the app, on tasks, etc. It's super zoomed in and you can't zoom out. Hard to capture full elevations when you don't have enough space to back off 25+ ft.
  • When selecting a hyperlink from a sheet > selecting sheet reference, the initial screen/view you're taken to is zoomed in very close- Jumping to a sheet should view sheet sized to screen initially.
  • Ability to copy/paste tasks/issues.
  • Text boxes do not Autositze.
  • Ability to rearrange and or favorite tools/ edit tool bar & location.
  • Ability to use one finger, not two, to traverse a sheet
  • When selecting a hyperlink/ mark up, the bottom pane doesn't come into full view. Sometimes when it's too small, you're not able to even select the reference.
  • When jumping to a sheet via a search, the surrounding sheets are not accessible. If I jump to sheet A-1000 via any filter, I should be able to swipe right for A-999 and left for A-1001 and not have sheets excluded.
  1. Web Browser
  • Correct clashing view in Correspondence View - i.e. subject only, etc. See Photo
  • When exporting Reports or RFIs, attachments should be able to be included as sheets. Would like ability to delete embedded links. We cannot submit RFI's this way and have to export and re-add sheets to RFI's outside of ACC.
  • When exporting reports, selecting export should export the report to .pdf automatically. Or when selecting Export, at least have the option to create link, export, etc.
  • Function from an application - not a web browser. (This could also resolve the major issues with Desktop Connector) Excel & word online have limited functions and are not user friendly. We also lose work alot, see next bullet.
  • Browser sheet resolution is exceptionally poor until zoomed in.
  • Ability to open Microsoft files in application and sync, (done we have connector anyway) since they’re supposed to be able to be live. (How teams functions). Also work simultaneously in live documents - not in browser. We loose too much worse when it "refreshes". When this happens, we lose work from the 3-5 minutes leading up to the refresh and are not made aware a browser refresh is coming.
  • When opening a task or issue, you can't expand it. Should be able to view as full screen or similar to RFI dialogue box. See photo.
  • When you create an RFI in the browser, once you click out of the initial RFI dialogue box & go to edit Description or Suggested Answer, you cannot hit "Enter" to go to next line. Should be able to do this to keep formatting clean. Would like ability to format &/o bullet/number lists.
  • When you click the sheet reference in a browser on plan, it doesn't go to the sheet... you have to click it again........ if the sheet reference is showing, should go straight to the sheet.
  1. General
  • Drawing Sets should upload in the order in which they are added. Not alphabetically. Our draw set is disorganized because of the inability to rearrange sheets (though we shouldn't have to. Like PlanGrid.)
  • Manual location inputs > Would like to be able to manually input locations that may not be in assets lists. For example, we have a mock up and cannot drop a task for this. We have experienced corridor issues that affect our path of travel, etc. We cannot put actual locations on these tasks.
  • Easier location upload - not double clicking room, etc.
  • Ability to assign tasks/issues to users / project team members. > "Assigned to" is an available filter, but assigning is not available in the task/issue.
  • Making user default settings apply to all projects.
  • Ability to bulk-edit sheet tags after being published.
  • Not having hyper link symbol on the plan views, it's messy and crowded. The mark up indicates the hyperlink would exist. Like PlanGrid.
  • When selecting a mark up we created to hyperlink an elevation, the shape often selects, it shouldn't be reading a shape, it should just be reading the fact it's a link to another sheet. Often times when this happens it ends up inadvertently being moved, resized, etc.
  • Ability to pin favorite folders or docs in files. Have to go through entire file path each time.
  • Ability to image search in addition to text, like Bluebeam.
  • For automatic hyperlinks created by ACC, selecting sheet reference shouldn't be required - jump directly to sheet.
  • Don't read ACC populated hyperlinks as mark ups - see attached.
  • Show more than 50 tasks per page ILO having to page through - show all on one window. Same with sheets.
  • Ability to show sheets like Bluebeam bookmarks without extra detail info. Condensed view for easier navigation.
1 Comment
jleeUFLBE
I like most of these suggestions, but I saw a few things that exist that might help you ahead of time.
Drawing order can be configured in Disciplines. Unless you are having issues with the Version set, and those should populate by date.
Select the sheets you want to edit, an Edit Pencil will pop up and you can bulk-edit the tags in the fly-out menu.
Hope this helps!
