Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Make markups visible in Issues add-in for Revit
At this moment you are able to use the Issues add-in in Revit to search for Issues created on ACC in that particular model. However, if you are creating an issue on ACC and are adding markups to that particular issue, you are not being able to see these markups in Revit (just the metadata, pin and attachments).
Especially when checking/remarking sheets in ACC, it would be really useful to be able to see these markups in Revit as well, as an overlay of the actual sheet for example (a bit like using DXF).
This way it will be much easier to implement those markups and close the issue.
1 Comment
naysa.luna
This would be very helpful.  I would add the ability to report markups as part of the "Issue" would be a big time saver.
