Use Case Scenario:
A project team shares a folder (with all its files) from one project (source) to another project (target) using the "Bridge - Share to Target Project" feature.
The folder structure and files successfully appear in the target project.
However, the folder attributes and their applied values, which are already configured in the source project, do not transfer to the target project.
Current Limitation / Problem Statement:
Even when "Automatically sync updates to target project" is enabled, the attributes remain confined to the source project.
As a result, project teams must manually recreate and reapply all attributes and values in the target project.
This creates significant manual overhead, inefficiency, and risk of inconsistency, especially in large-scale projects where folder attributes are extensively used for classification, filtering, and reporting.
Proposed Enhancement:
Enhance the folder sharing mechanism in ACC Docs to allow attributes (and their applied values) to be shared/synced along with the folder and files when using "Share to Target Project".
Provide an option at the time of sharing, such as:
“Include folder attributes and values in sync” (checkbox).
Ensure that subsequent updates to attributes in the source project can also be auto-synced to the target project (similar to how file updates are synced today).
If attribute master lists differ across projects, provide a mapping option or error notification so that users are aware and can align their attribute standards.
Business Value:
Saves significant manual effort in reapplying attributes.
Ensures data consistency and integrity across linked projects.
Improves collaboration efficiency when working on multi-project or multi-organization environments.
Reduces chances of human error in attribute management.
We kindly request this be considered as a high-priority enhancement for ACC Docs, as folder attributes play a crucial role in our clients’ workflows and reporting structures.
