It would be extremely useful if it was possible to change the placement of the issue pin in model coordination. Currently, once the pin has been placed on a modeled element, this can no longer be updated or changed to another element or model if required. For example, if the issue is changed to a different assignee or discipline, then the element and model pin placement should be updated to reflect this. This would also benefit the Revit Issues add-in tool allowing the correct element to be selected within the relevant model.
