Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
ACC Font Support
ACC Font Support
The title block that my company uses contains a font called "Figtree" which is not supported by Autodesk Construction Cloud. Is it possible to add the Figtree font (and other free fonts) to ACC's supported fonts so that drawings can be viewed correctly online?
4 Comments
simonNMZQT
Good Luck,
We are in the same boat, We use Swis721 LtCn BT. I reached out last year to Autodesk support without luck.
This was just in a 30 day trial and still havent moved onto purchasing as we are not considering changing fonts.
buildintel
Hi gents,
@npeddieson @simonNMZQT
Can I ask a little more info about your use of fonts?
It sounds like fonts are crucial to your workflow.
BI
ewetzel6ANN6
We have seen a lot of GC's who don't use a supported font so then during drawing upload we run into problems with sheets having blank title blocks and being out of orders.
npeddieson
When ACC replaces our Figtree font with Arial, the automatically sized text boxes remain the same. Since Arial is a wider font, it pushes the text onto a second line. I have since manually resized the text boxes to give them enough width to expand, but the Font replacement is not desirable.
Figtree fontFigtree fontArial replacementArial replacement
