I'm struggling to find the time that a Revit model is finished publishing to ACC from the API response. In the response, there is an attribute 'lastModifiedTime' which I was assuming would be what I was looking for. However, I believe that this is the time that the publish was initiated, as, in the responses it lines up (give or take a few seconds) with the time that my script is scheduled to run. Then, on the ACC side, the 'Last Updated' column has a difference of minutes to hours which would make more sense as being the time that the models have finished publishing (some of the models are very large).
My question being, is there a different endpoint that I should be hitting that would contain that data? currently I'm calling the Data Management endpoint - 'projects/:project_id/folders/:folder_id/contents' - and iterating through the models in that response.
Any and all advice welcome. Thank you!
